RCU Forums - View Single Post - ESM, Ever Soaring Models Any Good?
Old 03-27-2012 | 04:58 AM
mike day
Default RE: ESM, Ever Soaring Models Any Good?
    i have the beaver it was a nightmare first i through the hardware pack away the second was to put blind nuts in the wingroots to hold the wing in stead of rubberbands. tail wheel assembly sucked had to reconfiger that. the plane is real tail heavy from the start. i put a dle30 in it and still had to put two pounds of lead in the nose. the wing loading went out the window then. what if someone whould have put a glo on this bird it would have had to put two more pounds of lead in it. the fuse had a bad crack in the seam they are notorious for this. tbm shows how to repare this because so many are cracked. no dont think i will buy another beaver from esm.?</p>
