RCU Forums - View Single Post - Radiance F3A - new pattern kit
Old 03-27-2012 | 09:30 AM
  #43
Alex Voicu
Default RE: Radiance F3A - new pattern kit
Thanks Leo, we had quite a few questions about a glow version. For us it would be too expensive and time consuming to re-tool for glow power, buy engines and accessories, build and test a new prototype, etc. But for those willing to build a glow powered Radiance, it would be quite easy to convert the model.
Basically what's needed is to cut a new firewall, remove the frame indicated in the attached picture and build a fuel tank support. Additional reinforcements will be needed on the inside of the fuselage for attaching the firewall and also the cowl support tabs need to be reinforced to withstand the YS engine vibrations.
For the new firewall you can use the one included in the kit as a template, but without the big rectangular cut in the middle. I can provide a PDF file for the glow firewall and fuel tank support if needed.
The attached pictures show the modifications needed for glow power conversion:
ID:	1743489   Click image for larger version
ID:	1743490   Click image for larger version
ID:	1743491   Click image for larger version
