She's all done(except Imissed 2 screws on the tail wheel, will get that later when Irun her up.)
Ichanged the title, sinces it is a .52 and not a 40 running it
Imounted the switch and charge jack where the black of the decal is so it doesnt stick out. Ialso put a fueling line on so I dont have to unplug the line from the carb to fuel it, the line sticks out at the front left, and has a plug. Eventually I will get a fule dot like I have on my Dewey. Ilossely zip tied the fuel lines to the carb throat to keep the vent off the hot engine parts. Since the muffler is pointing down, I wont need to worry about taking the line off when I fuel, I can stop the pump when I see fuel in the line and reverse it to suck some out. If Ido miss it and some overflows, it will run down to the ground and not into the motor.
