RE: What do I call this part
“Are you sure that the crank spacer is bad?”
If you had a prop strike that would of very likely of twisted the crankshaft and this is very typical of any engines that have a crank that is pressed together. The good news is; is that it can be straighten very easily. You will need to check the crank with a dial indicator.
