200-215 degrees F is best temperature for break in just got to remember that run around 20% nitro with one that has a higher oil content to lubricate properly during break in and also your leaning and fattening will affect temperatures in any motor during a run
ORIGINAL: rcenth
I got a temp. guage and I was wondering if you knew what temperature the engine should be at during break-in and when it's running normal, and if it gets a higher than a certain temp does that mean it should be retuned to lower the temp. I believe i read somewhere that weather conditions also have an influence, and out here in Texas it's already starting to get pretty hot, during summer it's going to be burning hot. So would the temp of the engine be higher than normal in this case, and if so would I keep it as it is and not try to lower it?
<embed style="left: 0px; top: 0px; width: 0px; height: 0px; position: fixed; display: block; " type="application/rf-np-plugin" id="Siber_embed1"></embed>
