RCU Forums - View Single Post - Source for dural wing tubes
Old 03-29-2012 | 04:04 PM
erbroens's Avatar
erbroens
Default RE: Source for dural wing tubes
Ola Nuno, tudo em ordem?
I faced the same problem with the Viper wing tube.
I just used a thick wall (about 2mm) 1 1/2 inch o.d. aluminum tube wich is twice as heavy as the original one but stronger, even if it is not sold as dural. Later I sent it to a local machinist to reduce a bit the outside diameter to fit the airplane fuselage and wings.
Um abraço, Enrique.
