RCU Forums - View Single Post - Options for separate elevator halves
Old 08-30-2003 | 09:44 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default Options for separate elevator halves
You can get a bellcrank from Central Hobbies. You can use a single servo and install the bellcrank.
http://www.centralhobbies.com/contro.../Bellcrnk.html
You can use an Equalizer. It is essentially the same thing as a JR Matchbox- but about $20 cheaper. It allows you to reverse one servo and individually adjust the neutral and endpoints of both servos.
http://www.smart-fly.com/page3.html
You can use a JR Matchbox.
http://horizon.hobbyshopnow.com/prod...p?prod=JRPA900
Please don't use a reversing Y-harness. They don't work. You will always get differential throws with a reverser. You can use one if you don't need precision elevator throws, but if you want to fly precision or any competition- forget it.
There's a few options to get you started.
