RE: Tamiya DMD T-03 - doesn't work properly PROBLEM SOLVED
Are you absolutely sure that the reciever is plugged in correctly? Sound slike that might be the problem. Or...motor leads are in the wrong configuration. Again, a possibility. I would recheck these things first, as the rudder tim should hardly ever need to be touched on the tamiya.
