RE: Help???
I had the same problem . . . wore out a number of catalogues trying to find what I thought had the qualities to handle the gear. My final decision was a Hobbico NextStar EP, but they don't sell the EP version without the radio. So, I went with the Nitro powered version (plane only option) and converted it to electric which is very simple, as the nitro version is practically the same as the electric version (most parts are interchangeable). It has a 69" wingspan and requires a reasonably powerful motor, but it's worth the extra cost to give the space you need to install everything.
I first mounted the camera in a square hole which I cut in the windshield. the problem with this location was that the prop was always in the video. I fixed this problem by buildinga tower from 4 pieces of airfoil shaped strut material. It bolts to both sides of the fuse. stands about 8" above the top of the wing with a platform on top for mounting the camera and its pan/tilt servos. I ran the wires down one of the posts and attached it to the post with zip ties (small ones), then thru the side of the fuse. This setup looks a little wierd up close, but you never notice it when flying. Now I can pan and tilt the cam. in any direction without seeing the prop.
The NexStar is a very stable platform, easy to assemble (ARF) and the T.O. and landing characteristics are as good as you can get.
If you decide to go this way, I can provide pics. and more details on equipment installation, etc. Cell Phone: 567-224-2492
FROTHINGSLOSH
