a simple push-pull rod through the firewall will do, connected to a servo, or a crank instead of a servo. The crank can be operated from the fuselage side.
ORIGINAL: vertical grimmace
So how are you guys configuring your choke on this engine? I am having a hard time getting mine setup in a way that I can get to work well.
