RCU Forums - View Single Post - Engine noise
Thread: Engine noise
Old 03-31-2012 | 10:49 AM
vmeek
My Feedback: (38)
Default Engine noise
I have a very strange problem with a Spectrum receiver and a fuji 64 EI.
I seem to be getting noise when I start and run the engine.
I have isolated the throttle servo with 4in of nyrod the EI module is mounted on the engine block I have about 6.5 in. between the throttle servo and EI unit.
I have swapped out the EI with the same results.
I have the EI battery close to the receiver
Will moving the battery and and switch away from the receiver help?
None of my other planes have done this.
Also I have swapped out the receivers.
