RCU Forums - View Single Post - super decathlon fin
Old 04-01-2012 | 07:38 PM
orthobird
Default RE: super decathlon fin
bad news,
i moved the 3 servos from rear bay to front compartment,
the three servos weigh 11 ounces.
i had 15 ounces of weight under gas tank,
and another 3 ounces in cowl area.
after moving everything
i see it is maybe not tail heavy now, maybe,,
but i still have to use the 15 + 3 ounces
i was hoping i could use less weights,
i also checked that the surfaces on bottom side of ailerons and elevator were flush.
good news is that now, when i do CG test, the nose is slightly lower than tail, and the top of wing is completely parallel with the floor.<br type="_moz" />
