RE: I need help identifying an engine
it is a early early quadra , the early quadras looked a lot like the zenoah but it is a quadra 35cc with magneto ignition , bottom of the crankcase should say made in canada there should be numbers on rear cylinder head and crankcase , if so then it is a early quadra , the rear shaft is where the spring starter will connect to just like the zenoahs
