RCU Forums - View Single Post - DLE 20 choke linkage?
Old 04-02-2012 | 11:40 AM
ec121
Default RE: DLE 20 choke linkage?
I use a nyrod (turned/curved 90deg to make some friction) throught the side of the fuse. I put a servo screw in the end to pull on. When it is set right, the screw head is flush with the fuse when the choke is off. Almost looks like a cowl screw, etc. Sometimes a bellcrank is needed.
