RE: Prop for H9 Alpha 40
I've changed many Alpha's over to 11x6 two blade props, and have not had many issues with prop clearance.
The Alpha gets the nose up rather quickly and settles on the two rear mains at landing, so if the grass at your field is cut, or you are landing on asphalt, it is not a big issue.
