RCU Forums - View Single Post - How do I tap a engine mount hole?
Old 08-30-2003 | 05:41 PM
Fubar-One's Avatar
Fubar-One
Default Re: How do I tap a engine mount hole?
Originally posted by snyperx
How do I tap an engine mounting hole on nylon engine mount? I do not have access to a tapper. I also do not know anyone that has a tapper. Thanks.
As someone else said, if you plan to stay in the hobby you need to get one. I bought a set of em at Orchard Supply Hardware. Pretty sure it cost less than $20 and has a set of 5 or 6 drill and tap pairs along with a T handle chuck for the taps. I drill and tap ALL my nylon mounts leaving the last bit un tapped. I have yet to have a socket head screw loosen.
I do add a nylon insert nut on the end JUST in case.
