RCU Forums - View Single Post - How do I tap a engine mount hole?
Old 08-30-2003 | 07:16 PM
William Robison
Default How do I tap a engine mount hole?
snyperx:
You can also drill the mount slightly undersize for the screw, then cut some slots in the end of a screw and drive it through; that will cut the threads for you.
The proper way, as has been pointed out, is to buy a tap and tap handle, or a complete tap and die set.
Bill.
PS: You could also visit the shop where you get your car services, someone there should have the set. wr.
