This should be the last of the problems, I hope...
The hinges are glued in at the factory on everything except the stabilizer, since you have to slide thestab. into the fuse and glue in place...
Here is a pick of the hinges that they are using and the quality sucks on them, if you grab it and pull out wards from the joint, it moves almost 1/32" and what ever glue they used on them at the factory has bound them up but good.. Some of them are moving when you work the control surface, really piss poor if you ask me... The Hinge gap is also unacceptable to me, almost an 1/8" in places then add in the movement of the hinge and you see where I am coming from on this.. This gets better!
