RCU Forums - View Single Post - Maximum altitude??
Old 04-04-2012 | 12:08 PM
  #82
UStik
Default RE: Maximum altitude??
ORIGINAL: iron eagel
I always though that an electric motor was most efficient at it upper limit of rpms...
That's right, but as you see in the diagram the drive (including prop) doesn't "unload" much with more speed, or the other way around, even static rpm is quite high. So the motor's efficiency is not far from maximum and the propeller's efficiency is paramount.
