RE: Camera Help/Advice Needed
You can be pretty sure it is DC, as the vast majority of these are, it would make no sense to require AC input.
If it is meant as a reversing camera then it is a safe bet that it is 12 volt.
You could try 6V and it just should not work, if you think it might blow on 12.
But for automotive use it will be 12 volt.
