ORIGINAL: KW_Counter
opjose,
You missed the part about it being a cowled engine.
Normally I run the pressure tube into a retired fuel tank for retrieval.
Thanks All,
KW_Counter
I sure did!
ACDII's idea is pretty good.
The line doesn't have to run outside the cowl at all.
A more complicated approach is to put a secondary fueler on the pressure line rigged so that excess fuel flows out when you have the fitting in place.
