RCU Forums - View Single Post - Meister Scale P 47 - step by step
Old 04-05-2012 | 02:27 PM
  #366
mirce
Default RE: Meister Scale P 47 - step by step
Thank you guys...
OK, now back to P 47...
In last few days I was working on transition from the fuselage on the wing. Thin ply I get from Meister was not lean nice on fuselage, so I decided to made all from the beginning.
First I made template from paper to get right shape...
Than I made bottom side from 1,5 mm balsa...
Rear part follow down wing side...
I made first few 3 mm balsa triangles...
Than rear part of the upper side...
I glued it with Zap thin glue...
After that rest of the triangles...
Than I was making every part between balsa triangles. It was making from 1,5 mm balsa...
When I finished that stage, wing was take off the fuselage...
Because everything was working on the wing directly, no gap between transition part and wing. But, front end was not be done on this way, so I made it from few 10 and 5 mm thick balsa pieces...
Little sanding, and...
Now fuselage is ready for glassing...
And one more picture, look difference between Zero 2,1 meter wing, and Meisters P 47...
No more other projects, from tomorrow I start with glassing...
Regards from Serbia...
Mirce
P.S. - 023 - like in army, 23 more days to go to Top Gun...
