RE: Lets hear about your Thunder Tiger Neptune SB-1.
G'day Jim and welcome,when you click on post reply and the message box comes up at the bottom you have two links you can click on.
One is called BETA and the other says click here to upload images and files (I use this one).
1. click on the click on here to upload images and files,this will bring up a multilpe upload box that says browse at the right hand end.
2.click on this and then select the file/folder on your PC to upload from (i'm assuming you using windows),then select the pic you want to upload.
3.click on save and it then should come up on the file upload box.
You can upload multiply pics doing this and then when your finished click on ok,just becareful of the size of each of the pic's as the uploader may time out.
I'm having problems with the endurance of my Tx battery,it goes flat after a couple of minutes regardless of how long the Tx has been on charge.
I'll be changing the the radio out for one that is legal in Oz as the one that came with mine isn't.
cheers,
glenn.
