RCU Forums - View Single Post - Jato 3.3 Idle problem
Old 04-08-2012 | 12:42 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Jato 3.3 Idle problem
ORIGINAL: RockerTom
ok i will try that tomorow. But dont you think after 8 seconds the carb would have definetly returned to closed anyway even when the spring wasnt pulling enough.
Thanks for reply
Without seeing and hearing what its doing, I have no idea how to answer that. There's obviously a reason its acting strange. Either there is binding or maladjustment in the throttle linkage or carburetor itself, or there is a problem with the servo. Best thing to do is have it running and look at it and listen to it. sometimes you just have to mess with it as there's a lot of other variables that can come into play if the mechanicals all check out.
