RCU Forums - View Single Post - DLE-30 Running Rough
Old 04-08-2012 | 04:04 PM
WacoNut's Avatar
WacoNut
Default RE: DLE-30 Running Rough
ORIGINAL: w8ye
There could be several other problems to consider . . .
Are you running NGK spark plugs? No, I will pick up a couple plugs tomorrow
Is the prop still tight as the wood crushes in the beginning? The prop is tight
The plug cap could be not all the way on the spark plug? Verified the cap is tight
The ignition timing sensor could not be picking up the magnet well - too far away - magnet weak - etc I will look at this, worked well for 2 tanks.
What spark plug gap do you recommend running?
Anthony
