RE: How important/ critical is Prop Balancing?
Hi
Has anybody used the Vess balance ring ? Can you balance your prop on the dubro without the Vess Blance Ring ? I believe the shaft is long enough too. I have not found a accurate way to ensure the shaft is level and true within the towers to ensure I get a accurate balance ?
Also is it better to balance the spinner and prop at the same time or do them seperately ?
This is my first time messing with gas props I used to just used the cheap fingertip balancer.
Thanks Scott
