Finishing up the rear end. Before I disassembled the truck I did notice the rear chassis braces seemed loose, so I decided to use some nuts and bolts instead of the supplied screws. I think this really helped stiffen up the rear chassis braces. I also switched out the screws that hold the diff to the chassis with some longer ones and I decided to add some nuts and bolts through the lower arm mounts, I think that will keep the diff where it belongs.
