RCU Forums - View Single Post - Knowing when to replace bearings
Old 04-08-2012 | 09:42 PM
378's Avatar
378
Default RE: Knowing when to replace bearings
ORIGINAL: The_Shark
if i was you, i would eat ramen noodles and give up R/cs for months and get your suspension system fixed, it can go for 200k miles or break with no warning today
I don't have the option of doing that either. That would put my truck down for the count for at least a couple of weeks. My dad currently has to rely on mine to get to work because the brakes just kind of stopped working entirely on his truck. Pedal just drops to the floor, nothing happens.
If I put mine on stands and start working on the steering linkages he won't be able to get to work.
I am fixing it as best I can. Six months ago the ball joints in the I-beams that hold the knuckles on were so badly fubar that the tires had about 3-4 degrees of negative camber and would flop around like crazy. The steering had about half a turn of play in it then. We put new ones in it as soon as we could afford to and we didn't have to rely on it just to get to work...and matter of fact the next thing that will be addressed will be those very lnikages. But to change them we need to save up the $150 or so the alignment shop will want to set the camber and toe(We just eyeballed the camber when we changed the balljoints, it's close enough for now) on top of the cost of buying the parts, and that will have to wait until after we put $300 worth of brake parts into the other F150. It may be another year before I get those linkages changed, longer still if I manage to land a 9-5 of my own and have to commute with it.
point im making is take care of what you have, even if it takes sacrificing your time with it or sacrificing something else.
I'm well aware of that. I wouldn't have gotten to 300,000 miles if I didn't take care of it.
