RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 04-08-2012 | 10:22 PM
  #269
clivemc
Default RE: OS 33GT Gasoline Engine for Pattern
ORIGINAL: PlaneKrazee
Mid throttle richness with my MT 70 was corrected with lighter prop load. I was able to lean the high end which in turn cleaned the midrange.
what prop were you running and what did you switch to? usually if you dont load it enough you get mid range burbling and by upping the prop / load you can get it to tune and run better.....
