RCU Forums - View Single Post - Ford CMP Gun Tractor build
Thread
04-09-2012, 02:41 AM
3
AFV432
RE: Ford CMP Gun Tractor build
heres the chassis built from brass and the wheels and rear axle modded to look better and have the wheelbase at the correctish width
rear axle and one side done just a wheel hub with fake bolts to add to the depth the hub end is from an old pershing wheel
the otherside showing the parts needed from the halftrack
installed rear axle showing the rough placement a set of rear leaf springs will be made to give a bit of movement here and also achieve the correct wheel height
front axle removed from the halftrack and added to the chassis i may have to reduce the height on this one and strech the front axle a bit with this i can correct the drive hub to a central position
Reply
Like
AFV432
View Public Profile
Send a private message to AFV432
Find More Posts by AFV432
View iTrader Profile
