got the chassis rear axle mounts fabbed and soldered on
leaf springs made from steel pallet banding cut into strips and added the lengths together all held inplace with some heatshrink
bolted on using some brass bolts and nuts
fixed to the chassis using M 2.5 allen head bolts
showing the suspension travel
and finally with the body on
all i need to do now is fabricate a front axle make some more leaf springs and get the soldering iron warmed up :O
