RE: How important/ critical is Prop Balancing?
You can balance props and spinners separately. Would be hard to rig all together anyway.
I always balance props, then track the tips and finall hub balance.
I use the same Velcro trick for inside the spinners to get them true.
If you still damage props regularly then it's probably too much work so forgo the hub balancing ang tracking but still balance the prop horizontally and the spinner.
