RE: Stumped
Depends on the radio. I solder on longer leads(cut off one end of an extension or solder a piece of wire in the middle.) to eliminate a connection then use two channels for the ailerons with shorter extension on the rx. I don't like extensions in the wing where they can't be inspected. A more basic radio might require a Y harness.
