Hi, Guys,
I have the honor to bring you a revolutionary FPV cam, HoryzonHD.
It's a 1080p video cam that take Full HD onboard video and store it in the
memory card, and transmit the PAL or NTSC video signal to the ground station
through video transmitter.
I adopted a separated sensor module design that enables many possibilities.
you can now use a tiny pan/tilt to take HD videos.
the whole unit is only 38g including the monitor and less than 30g without the monitor.
Parameters
Lens: 120 degree wide angle. (140 degree with Gopro lens)
Sensor: 5.0 Megapixels CMOS
Video resolution: 1920x1080 30fps
1440x 1080 30fps
1280x720 30fps
1280x720 60fps
Photo resolution: 2592x1944
Video formate: H.264 encoding
Audo: built-in Microphone
Memory: Support Micro SD card(TF card) up to 32 GB
Power supply: 5V DC (directly powered by radio receiver)
We are going to send 10 free samples to ones who is interested in this new cam for reviews, the requirements are as follow:
1.you must have a Youtube or Vimeo Channel that have more than 100 subscribers, and it should be based on RC models, and please post your best FPV or similar video in this thread. we will check and select 10 test flyers based on the videos and your video channels.
2. you need to do a test video and review ,and put it on Vimeo or Youtube
with our logos on it.
3. we will use the fastest shipping method to send samples, and please make the review and video within 2 weeks after you have the HoryzonHD cam.
all 10 test flyers will be selected before 4.25 th. and we will send you the samples.
here are some demo videos below that i made by myself
for any question, please write emails to us:
[email protected]
[email protected]
the final product will be finished around April 15th, so all the photos in the following link are prototypes, the final product will surely have better looking.
http://www.foxtechfpv.com/horyzonhd-...cam-p-498.html
