RE: How to convert an ATX power supply to rc use
yes for the sense wire with the 5v, all grounds are the same, so i can rule this out.
i will remove the board from the case and try to follow the traces, but even if i find that there is 1,2 or 3 rails, it should not matter to why it can't keep its voltage under load ?
