Honestly, I thought the bottom end with the Volcano tranny was lacking
These say they fit in all HPI engines, which includes the Savage. The savage, and the Savage cluthbell fits the SH 18. So for 6 dollars, I think I will try one and see what happens.
Failing that, I'll get a
13T savage clutch bell (not from that store, their price sucks and they don't even have it in stock), and try that. If it STILL doesn't work, I think a
47T savage spur gear could be jammed into the Shockwave tranny with a little bit of dremel work, maybe even a few teeth larger. Then, with at least a 13T clutch bell and a 47T spur, it should be a little better.
EDIT: Also, a lot of people on RCUhave said that
this direct drive conversion from All About Fun Hobbies is an inprovement in both top AND bottem end, because its geared a little higher, and removes all the frition and rotational mass of the Volcano gearbox. It is a shockwave tranny and 13T bell, so I'd be inclined to think that a 13T bell could even work with the unmodified shockwave tranny.
