RCU Forums - View Single Post - How important/ critical is Prop Balancing?
Old 04-10-2012 | 02:55 AM
  #42
jaka
Default RE: How important/ critical is Prop Balancing?
Hi!
Problem with using a drill bit to enlarge a hole in wood (or any material) is that it can wander sideways a bit!
Best way to enlarge a hole in a prop is to use a stage reamer!
And balancing is soo easy to fix with just a file and sandpapper! Adding anything to
(spinning) prop scares me. We are dealing with props spinning at high rpm here, not full size props at low 2000-3000rpm!
