RE: How important/ critical is Prop Balancing?
I buy both xoar and vess props and both brands require very little balancing. Since their wood line of props are already clear coated all you have too do if remove some of the clear coating material. This is done by using a piece of fine grit sandpapaer removing some of the clear coating from the backside of the heavy blade. Simple process and takes less the five minutes to accomplish.
