RCU Forums - View Single Post - DLE-30 Running Rough
Old 04-10-2012 | 03:21 PM
WacoNut's Avatar
WacoNut
Default RE: DLE-30 Running Rough
ORIGINAL: R/C Foolish
Which way did you move it? Can you send a picture? I'm having a similar problem...I guess I can just try moving either way until it runs better.
R/C Foolish
I suggest you visit this thread[link=http://www.rcuniverse.com/forum/m_11012341/tm.htm]DLE-30 Problem[/link] There is a video posted on how to check the timing as well as a template you can print out to help check and set the timing. I would not suggest just blindly moving the timing.
Checking and setting the timing was easy after watching the video and using the template. I have laminated this template and will be using to check the timing on my other engines as well. Very hand tool to have around.
If you still need pics I can take them but it will be a few days. I am working long hours and I have my plane locked up in my trailer at the moment.
Later!!
Anthony
