servos twitter w/o tx...whats up?
Same here, infact, I know guys who had the receiver FLOATING on feul, and it still went fine after it was dried and cleaned. I noticed that you can get alot of interference when you don't have the radio on. Maybe its as simple as that. Try a range check, with and without the engine running, and if everything turns out fine, then there shouldn't be a problem. Also, make sure that there are know extension leads, or metal rods etc. running close to the receiver. If you have a nice clean set up, and the range check shows no problems, then I would say it should be alright. Are you using a Dual Conversion Receiver?
Robert.
