RE: ATF kit not ATF!
There is nothing ion the motor as to what the spec's are. It just says, "Thunder Tiger OBL 29/09-07A Warning! This part rotates. There is nothing in the manual or at the Thunder Tiger web site, or any web site that I have found for that matter that gives the spec's of the motor. I have found the same motor for sale a couple of places but no spec's.
I have found that the Battery required is an 8 cell 9.6V 600mAh Ni-Mh type and the plane manual suggests using an ACE BLC-12 BEC.
I thought the motor had a red, black and green or grey wire ,but after I went and got the motor, I found that the wires are red, black and yellow. Thanks for the info on the wiring.
I did contact the hobby shop where the plane was purchased but he said that his supplier will have to contact the mfg as the part no.'s in the manual are not good and who knows how long it will take for a reply.
Thanks again.
Ed Miller
