RCU Forums - View Single Post - ATF kit not ATF!
Old 04-11-2012 | 06:16 PM
pkoury
My Feedback: (7)
Default RE: ATF kit not ATF!
ORIGINAL: allelectric
All 3 wire motors can be hooked to any of the 3 connectors on the esc. If you power the motor up. If it is rotating the wrong way. Change any one wire and the motor will reverse direction. Wiring from motor to esc can hook up in any combination. Don't know if this helps. I am not a Guru by any means BUT, I fly only electric aircraft and have been flying electric since Nicad's.lol
Jeff
May All Your Landings Be Smooth!!!!!
How do you change one wire?
