RE: Spartan hatch
ps them 2 little water drain holes on the rear will suck water in quicklike oh and not to mention the front of the clunky flexible abs plastic will pull out almost every time. i ended up gluing some balsa under the hatch and putting a blind nut in with a knurl and cut off bolt to secure the front from coming out but now you just made another hole for water to enter.
