RE: ATF kit not ATF!
And NEVER set up an electric airplane with the propeller installed. A motor that is running in reverse or one that has the throttle servo setting reversed can run away from you or run into you when you least expect it. electrics can cut you worse than a gasser or nitro engine because those blades are sharp. Once you are assured the throttle and direction of rotation are proper then isntall the prop.
