RCU Forums - View Single Post - A123 battery too much for 4.8 V rated servos.
Old 04-12-2012 | 07:29 PM
Bill Rademacher's Avatar
Bill Rademacher
My Feedback: (77)
Default RE: A123 battery too much for 4.8 V rated servos.
Well, I am running a lot of planes with A123 batteries without regulators.
But, I have a scale FW-190, and prior to a test flight, I smoked 4 hitec servos inside the fuselage (using ar7000 receiver). One on throttle, the other two on elevator and rudder. I also smoked the retract HS-81 servo.
Everything worked fine on the bench before going to the field. I have since put a regulator in that plane. I already had one on a separate A123 ignition battery.
Not sure what happened, but I smoked them good.
billrad
