RCU Forums - View Single Post - ESC Programming Versus Transmitter Programming
Old 04-13-2012 | 07:11 AM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: ESC Programming Versus Transmitter Programming
ORIGINAL: BKoz559
I tend to agree that it has a lot to do with marketing, however, not all drivers have the same equipment so some folks may rely on those setup options in their ESC. Unless you're highly skilled (the actual phrase I was going to use may not be permitted on the open forums) and can modulate precise throttle control then most drivers, including myself, usually dial in some throttle exponent to take the edge off the power delivery. I may adjust the ESC's brake setting so that it doesn't immediately lock up the wheels when you barely flick reverse but other than that I don't mess with the ESC settings.
The one setting I've really had to mess with on my savage flux. Had to turn it all the way down to keep it from flipping over from just tapping the brake.
I've also messed with timing on one motor to try and get it not to cog, but turns out that motor just plain sucked.
I got a CC MM in my truggy, and honestly never saw the need to touch any of those advanced settings.
