ORIGINAL: Doug Andre
kahlog,
Great spinner!
I have a spare pair of correct Swastika stencils sized for Red 3 that you are welcome to if they fit your intended scheme. They represent the largest version applied to the FW during the war. They were taken from the Crandall book . Send me your address and I will mail them out!
I have had great luck with the APC 20x8 E prop and will stick with it . Speed is lower but flight time has jumped to 8 minutes at reasonable speeds with a few high speed passes. Vertical performance is just right.
Regards,
Doug Andre
Doug,
I am happy that 20x8 is working for you, but do not be affarid to try a 19x10 once you get comfortable with the plane. Your flight times will get even longer, max speed will increase and vertical performance wount suffer.
Thrust me, I know what I'm saying
@ TA152
You better check those engines of yours, one seems to be faulty
Velco
