ORIGINAL: blw
Jimbo, Saitos will spit fuel out of the carb. The velocity stack cut my mess down to almost nothing on my 72.
Do tell blw......
Where is a good source for them?
I took the carb off and this is where it was set.. Should the slit be in the center of the carb, or is it fine off set like it is? It also looks like more then 1mm, I closed it some in the second pic.. I know that I will have to fine tune it, is the manuals way of doing it the best way to set the low end?
