RCU Forums - View Single Post - Suggestions on programming Spect DX7 and Eflite Super Cub 25E?
Old 04-14-2012 | 04:12 AM
Geardaddys
Default Suggestions on programming Spect DX7 and Eflite Super Cub 25E?
Hoping someone here has some suggestions for programming the DX7 on a 4 panel wing such as the super cub.. I have a 7 channel receiver, so I don't need to use any Y extensions (I think).. Anyway, the confusion is weather or not I need to use flapperon mode, or just standard? I'm in standard mode now.. Rt. Aileron on Ch2 and Left aileron on 'gear' on receiver.. PMix5 has 100 percent both ways mixed Ail-Gear... For some reason, the left aileron movement is restricted in one direction, and throwing the gear switch is overdriving the servo (which would be bad in flight if I accidentally hit it..) Anyway, I'm sure this is an easy task, but I only use the DX7 for helis to this point and I'm a bit lost with airplane programming on it!!
Thanks for any suggestions fellas..
GD
