RCU Forums - View Single Post - X-plane as a R/C simulation
Old 04-14-2012 | 08:55 AM
jetmanhuss
Default RE: X-plane as a R/C simulation
ORIGINAL: GarySS
Can you set up X-Plane ''camera'' to where the view/perspective is stationary on the ground with the scene following the plane? IE like you were flying a model?? And the controller as your transmitter with set up as per an RC situation?? ?
Hi.
Yes, you can set up the camera to a stationary view on the ground, and the scene will follow the plane.
Now, X-Plane is not a designated RC simulator - For example You will have to manage the zoom by yourself since there is no auto-zoom.
For the controller issue: Again, it is not a designated RC SIM, But you can use any controller that you computer recognise.
It seems like a lot of issues, and it's true. But when it comes to simulation it's very realistic (you will need to use a fine tuned models).
Check the link below for some tips using X-Plane as RC sim:
https://sites.google.com/a/vskylabs....tup-in-x-plane
